Retractable seat belt install
nbcbird
Yes, the same foam used for insulation/sealing gaps in home construction. I used the regular variety (not minimal expanding) to make sure the entire cavity is filled. All the trim fasteners were removed and the corresponding holes were used for access and relief of the foam as it expanded. I can't remember whether the foam expanded into the side bulkheads of the footwells or not, so be careful in application around the front section.--Jim
  • Replies 36
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Yes, my sunroof drains tubes were moved to the top if the fenderwell (as in Mike Macartneys restoration book) and was a big reason to try the foam. I has a negative response saying the foam would retain moisture. But if it is installed in dry conditions and expands to fill the entire void, I can't wonder what the difference would be compared to paint. I also sprayed a liberal amount of rust treatment into the cavity a few days before insulating.
I also used the foam in the cavity formed by the triangular box on top of the inner rear fenderwell (that the shocks mount thru). This can be accessed thru the bulkhead of the rear seats.--Jim
  • 1 month later...
I completed the install of seatbelts yesterday using this method. The crux of the job is getting the nut and washer onto the bolt that secures the retractors. I wound up duct taping the nut/washer together and then to my finger, carefully placing the assembly into the access hole, and praying that the whole thing didn't drop into that cavity. I was successful both times, but there is a moment of faith there where you can lose the hardware in the empty area. read: go find a magnet. Overall very happy with the result. Big Thanks to Al for his great workmanship and communication.
1970 Agave work in progress
Born on May 14 1970 and delivered May 19th 1970 to NYC to Hoffman Motor Corp. Agave code 071
new guy
help appreciated!
other cars: 1991 318is / 1999 540iT
wanted to post some pics of the belts that Al Bludevils did for me with help from Brandon B in TX who rechromed the rear Klippan rings. They turned out great, and Al was very thorough. Great communication, and attention to detail. Thanks again Al
new guy
help appreciated!
front bumper on its way back from Brandon now, so standby for that pic . . .
new guy
help appreciated!
  • 11 years later...
  • 1 month later...
