Shortening Ireland Throttle Cable?????
SeanH
Hey there,
Anyone have any experience in shortening the throttle cable that comes from Ireland Engineering? Do I literally have to pull the ends off the cable? That just doesn't seem right and Ireland Engineering is exhibiting their usual fear of email.
I can post pictures later tonight, but just in case someone already knows what I'm talking about . . .
Thanks!
Sean
I'm into motorcycles and this is how it can be done on motorcycles. I have never seen a IE set up or cable.
I'm assuming that the IE throttle cable has a fitting that can be moved along the inner cable (for length) and it can be removed to cut the sheath down.
Hope this helps,
If not, I'm just a newbie trying to look brainy!! LOL
The sheath ? (the outer part)
For the sheath
Figure out how much it needs to be cut down and pull the end off the inner cable. Now, pull the inner cable into the sheath, just behind where you need to make the cut in the outer cable.
DONT pull the inner cable completely through the sheath, it will be very hard to get back through. You want the inner cable to sit just below where the cut is going to be made on the sheath.
Cut the sheath and then push the inner cable back through the sheath. You may need to "thread" the inner cable back to get it to come out and not completely fray the end of the inner cable (spin the inner cable in the direction of the way the strands are twisted on the inner cable). You may also need to cut a small portion of the inner cable to get to where the ended arent all frayed so your end will fit back on the inner cable.
Inner Cable
If you need to shorten the inner cable, just mount the cable up and run the inner cable through the end to where it would work fine and when it is installed, cut off the excess..
Fishhead
Fishhead
Motorcycle Big Brake systems
Be yourself and be free with your thoughts because those who matter don't mind and those who mind don't matter..
