FS or Trade: #73's Part List {November}... Found More...
#73
Found More Stuff... Updated 11/25/09...
All questions answered, all offers considered.
Email best/quickest: thedigitalplan@optonline.net
Local (Tri-State) meet-ups great (prices below = 'local'), shipping possible. (For peace of mind, shipping through eBay w/ PayPal + 'Buy Now' for items over $10).
Note - Re: Rotors = heavyish, so ship out is a bit up there - best rate I found was fitting either set in a USPS 'flat rate' box @ 13.95! Local meet up is most cost effective for them.
FS or Trade*:
Heater/Fan Plate (New - minor shelf storage microscuffs) $3
25 pieces Molding Clips (New - in bag) (these don't have the foam cushion/sealers...) $5
Early Front License Bracket (New - scratches/scuffs from storage & label removal) $7 ~SOLD~
1 Behr Thermostat, 1 Wahler (Used no cracks, just need clean up - I believe both are 75 degree) $7 each
Early; Raised Rear Roundel $14
Late Front License Bracket (New - light scuffing from storage) $14
Shifter Surround & Boot (Used - Some nicks on base, small rips on vinyl boot - see pics) $15
5 Blade Fan (New - Excellent) $20 ~SOLD~
Prothane Poly Bushings (New /Never Used - 2 for Differential Carrier) $21
2 Waterpumps (New, In Boxes) $22 each
PBR/Axxis/Metal Master Metallic Brake Pads (New - still wrapped, Asbestos Free 76.5mm for base 02) $24
Tanner Panel Ignition, Start, Accessory Switch mounted on aluminum box & wired/fused (Some Scuffs, Scrapes) $25
2 Passenger Side Late Grilles (Used but clean/nice... pics Pending) $32 each
2 ATE Drums (New - Unused, Rust Marks on some of outter {non-contact} edges from storage... see pic) $34 ~SOLD~
ATE Slave Cylinder (New - Very Slight Surface Oxidation Specs by Part#... see 2nd pic below) $36
Distributor from 320is (Used - Good, 97K miles) $39
2 ATE Brake Rotors (New - Unused, Minor Oxidation specs from storage) $40 for both
Prothane Polyurethane Bushing Kit #3-201 (New/Never Used - for both Front Control Arms and both Under Tow /Tension Rod/Front Support) $42
Prothane Poly Bushing Kit #3-202 (New/Never Used - 4 piece Rear Arms) $42
Rear Wheel Arch Repair Panel Belgium Made by Van Wetzel International (New - a few tiny oxidation specs... 'biggest' in 3rd pic below) $44
Tii Downpipe (Used - Good, Solid Cond. Refurbished... Wire brush: rotary coarse, medium then by hand w/ fine brass, finally double coated w/ POR20 {the 1400 degree version of POR15} Pics Pending...) $50
Luisi Leather Steering Wheel (Leather is nice but a bit light throughout - could use recolor/dye - or as is in daily... works w/ Nardi/Personal hub & horn button- not included, ~350mm/just about 13.75 inches) $77
Tii Clock w/ the "BMW MotoMeter" face, collar, wires, bulb (Used - Fair+ Condition, lens some microscratches & spots, worked {time and light} when removed, mount posts taken off?! by previous owner of tii... was in dash: wired but unsecured, collar has a crack & glue residue inside... left inner screw near '9' has nick... see pics) $88
MOMO Benetton Steering Wheel (Used a few Months, Nice Shape ~8.75 out of 10 - a few micro marks/scuffs on leather, some small nicks on 'spoke' metal area. Horn/hub not included, ~350mm/just about 13.75 inches) $101 ~SOLD~
Tii Manifold (Used - Good, Solid Cond. Refurbished... Wire brush: rotary coarse, medium then by hand w/ fine brass, finally double coated w/ POR20 {the 1400 degree version of POR15}, includes unused mani to down gasket w/ 3 stainless T.H.E. bolts and stainless lock washers... I wound up using a header) - $115 ~SOLD~
2 Weber 40DCOEs with Chrome(d) 2 Piece Intake Manifold, 2 K&N Chrome; Oval Filter Assemblies w/ filters, and mounting hardware (More/specific info and detailed Pics Pending) $515
OTHER:
1987 BMW 325 es Running Parts Car $345
More Info/Pics:http://newyork.craigslist.org/wch/pts/1484178146.html
*WANTED/can Trade above stuff for:
Looking for a Driver Side firewall; front of engine plastic 'Shroud' (need better shape than in pic!)
Looking for a damaged front Air Dam...
Thx,
__/ 0| \ _
'-O----O--' #73 (I'm looking for a couple of parts *here* / 4 Sale parts *here*).
e mail sent:
poly bushing kits(all)
not too long ago, i bought the break drums from you. if you remember. Thanks.
- vince
68 02 manila VIN# 1662166
76 02 parting out
kbmb02 - emailed.
twenty02 - emailed.
bcthomas122279 - emailed (through FAQ).
jdirecto - roundel pics above, one request ahead of you, will let you know if 'no-go'.
Brandon73fjord - emailed,
TMK_74_2002A - emailed.
I believe all other emails responded (in order received).
Let me know if otherwise! Thx.
Prost!,
__/ 0| \ _
