making quarter glass seal better
eaker02
after paint and headliner, re-installed orginial quarter windows rubber seal and glass. during the wet sanding water, was dribbling in between glass and rubber.
Is there a way to make an adjustment to the glass so there is a better seal?
thanks
ron
74tii
upon reinstalling the quarter window, there are a few tiny variables that can change, thereby requiring some adjustment. I even had nice new seals installed and still for some reason had to adjusted mine tighter.
Adjust by the two screws that hold the window opening to the c-pillar... they move back and forth. On one side I actually had to put in a thin washer under just the front screw to place the opener at more of an angle... seals fine now. Note that I don't think they ever sealed so tightly as to prevent a high pressure stream of water from trickling in.
hope that helps... maybe others have some different tips?
Rob
1966 Mustang vert - 5.0EFI/AOD & mods
1975 '02 - the typical upgrades (my 'new' car)
