5 speed swap questions
1972fritz
so i am going to be picking up my five speed this coming weekend and i had a few questions. 1st do i need to shorten the shifter mount because of the extra length also what about the selector rod? as far as the drive shaft goes can the 4 bolt output be swapped? and what is the best relocating mount for the trans needs to be strong?
There's a lot more to a 5-speed conversion than the gearbox. Check out the link frank listed and also this: http://www.bimmers.com/02/ On the left scroll down to Go Fast Upgrades and click Transmission.
After checking out the article above, you'll see why you can save yourself a lot of trouble by buying a conversion kit from Rob Torres at 2002 Haus http://www.2002haus.com/kit/index.htm or Dave Varco at Aardvarc Racing http://www.2002parts.com/html/5speedconversion.html
Curt Ingraham
1972 2002tii, 1976 2002
Improved 2002 Radiators
At a bare assed minimum, buy 2002Haus' U-shaped conversion bracket. Best hundred bucks for a piece of steel you'll ever spend!
1972 tii (Louie), 1973 2002 (Hampton), 1975 ti tribute (Bertha), 1972 Bavaria, 1973 3.0CSi, 1979 Euro 635CSi, 1999 Z3, 1999 M Coupe, 2003 530i sport, 1974 Lotus Europa Twin Cam Special (I know, I know...)
