Light rust in newly repaired gas tank - what to do?
im3crazy
Had the typical pinhole leak from a failed gas tank to body seal.
I checked out the tank and there was no sign of ANY rust or other damage- looked new. Then I had a local radiator company boil it out and braze repair the leak. When I got it back, it was a great repair, but it had a light rust coating in part of the tank.
What's the best approach? Can I remove the flash rust with a mild chemical wash, then fill the tank? (TSP, Evaporust etc). Or do I have to go all the way with a POR15 tank treatment?
Searches here showed a few similar questions, but no really good answers.
Tanks in advance!
1969 2002 Sahara  Manila  :)
Dave,
I was thinking... Maybe something mild like vinegar that is pretty mild and easy to clean out to get the rust off. Add a chain to give it a little mechanical help while you swish it around. Rinse and dry with a heat gun or in the hot sun...
I also used some eastwoods metal wash in the past with pretty good results on bare metal parts. Not sure how it would do in a gas tank but it works pretty well for keeping the rust off of my welding projects.
KC
...do you wash your underpants while wearing them in the shower ? (C.D. - 5/28/2009)
Thanks for the ideas on this. I'll take another look, but I don't think it's flux spatter - seems just a light spotting- doesn't appear raised or bumpy, and it's light brown.
KC: Good idea on the vinegar, that would be mild enough. I was hoping not ot have to flush water in there, so the vinegar flush and fast dry might work. I thought if I gassed up right after the wash-out I'd be ok without doing any further treatment like a phosphate (TSP).
