BRAKE FLUID & a ton of other stuff according to BMW
c.d.iesel
for the YOUNG ONES - and a refresher for
old pfharts
Brake fluid, (glycol-based) as used in BMW brake systems, must conform with the following requirements:
— High boiling point
— Good low temperature resistance
— Low compressibility
— Corrosion inhibition for all metal parts inside of brake system
— Compatibility with all rubber parts used in brake system
These requirements are fulfilled by reputable brand name DOT 4 brake fluids.
Silicone-based brake fluid has better compressibility, but because
it cannot absorb moisture, is subject to vapor lock
attemperatures above 212°F/ 100°C. At lower temperatures, it
may even ice-up. Silicone-based brake fluid is not approved by BMW.
Glycol-based brake fluid absorbs moisture from the atmosphere (hygroscopicity) through the brake fluid reservoir, brake
hoses, etc. This absorption of water lowers the original boiling
point of brake fluid and active safety of the entire system.
If there is extended use of the brakes while driving downhill at high speeds, the thermal loads could cause vapor bubbles
in the brake fluid. This situation could lead to reduced braking effectiveness.
The original boiling point of factory-approved brake fluids is
approximately 500°F/260°C. Due to the hygroscopic behavior
of brake fluid, 2% of water within one year is permissible. The
boiling point of brake fluid will drop by 100°C with 3% water
absorption. It is essential to conform with brake fluid changing
intervals in order to guarantee the safety and maximum
effectiveness of a brake system.
It would not be sufficient simply to replace the brake fluid in the
reservoir. Experience has shown that vapor bubbles will
occur first on areas of the brake caliper. This area is subjected to
high thermal loads and also exposed to heat transmission.
When replacing the brake fluid, the brake fluid used as the working
fluid in the hydraulic clutch should also be replaced.
This is done by draining the clutch operation system or bleeding
with the help of the clutch slave cylinder.
The brake fluid should be replaced by filling the brake fluid reservoir. Make sure that each bleeder valve of all wheel
cylinders or brake calipers is kept open until the escaping
brake fluid is clear and without air bubbles. Never use brake
fluid that has been drained from the system.
Storage of brake fluids also deserves your special attention.
The aging process begins with the initial contact between the
brake fluid and the atmosphere. This means immediately after
a new container is opened.
To keep the boiling point of stored brake fluids as high as possible,
we recommend conforming with the following points:
— Close all containers tightly.
— Select small size containers, which can be used up quickly.
— Avoid pouring contents of one container into a different container.
2.0 Handling Brake Fluids
Brake fluids could be mixed up accidentally with mineral oil
products so it is important to leave them in their original
containers and not pour them into a different container.
Caution
If brake fluid accidentally comes into contact with your skin,
wash it off with soap and water immediately. Eyes should be
thoroughly flushed with cold water if contacted by brake fluid.
Vomiting should be induced if brake fluid is internally
consumed and a physician should be consulted.
If brake fluid is spilled or drips on a painted surface, wash it
off with water immediately to prevent damage to the paint
finish. Never rub it off. Brake fluids should not have contact
with grease or oil. Wash hands to remove grease and oil before
working with brake fluids. Also make sure that grease cannot
enter the brake system.
Drained brake fluid must never be discarded in the garbage,
oil disposal tanks or water drains.
Read instructions on container label prior to use.
3.0 BMW Tested And Approved Brake Fluids
BMW Tested and Approved DOT 4 ESL Brake Fluid is available as follows:
12 fl. oz. bottle BMW Part No. 81 22 0 142 156
1 gallon container BMW Part No. 81 22 0 142 155
See S.I. Bulletin B 34 09 01.
4.0 Brake Fluid Change Intervals
All Models Brake fluid change interval every 2 years.
5.0 Other Operating Fluids
Anti-Squeak/Corrosion Paste
Bostik NEVER-SEEZ® to prevent disc brake squeaking.
It is applied on cleaned recesses, pressure surfaces of
piston crowns, brake pad backplates and possibly transfer
plates - but not on friction liners.
To prevent corrosion between the ABS impulse sensor and
the hole in the wheel suspension component, apply a thin coat
of Bostik NEVER-SEEZ® to cleaned sensor and hole before assembly.
Bostik NEVER-SEEZ® Part No. NSBT-16
See S.I. Bulletins B 34 02 94, B 34 05 98, and B 34 03 00.
Brake Cleaner Spray
Non-CFC spray (former BMW Part No. 81 22 9 407 704)
for cleaning brakes, brake pads, brake shoes, drums, disks and
other brake components. Also suitable for clutch pressure plates.
3M Part No. 8895
Loctite Part No. 82220
CRC Part No. 08088
and other TOP Secret stuff for my buds :
more usless information
1.0 Introduction
2.0 Corrosion Protection For Vehicle In Long-term Storage
3.0 Conversion Table
4.0 Alternate Universal Lubricants And Workshop Supplies
5.0 Approved Operating Fluids Sources
1.0 Introduction
These operating fluids specifications describe the standards
which are necessary for approval and application for
BMW automobiles. Operating fluids are arranged in vehicle
group category and are approved for all assemblies. Any
reference to a particular fluid contained in an active Service
Information Bulletin since January 1987 will be listed next to
the fluid’s part number. Before applying operating fluids, it is
important to make sure that the specifications and
manufacturing codes on the container conform with those
on the enclosed specification list.
Prior to their approval, all operating fluids are tested in detail on test stands, in laboratories, and in cars during field tests.
As new information is received, the Operating Fluids Manual will be updated. Some lubricants or fluids may be listed in
more than one specific group.
For example, Part No. 81 22 1 468 879 (Pentosin CHF7.1 Fluid) is listed under Group 32
(Steering) as well as in Group 37 (Integrated Suspension Systems).
BMW Car Care products are listed in Group 99.
BMW of North America has also approved various fluids for use which are not available through the Parts Department, but
may be obtained locally. A list of these approved fluids is found on sections 4.0 and 5.0.
Some fluids have been phased out of PDC inventory. Such fluids will be marked by an asterisk (*) after the part number
along with the name(s) of alternate supplier(s) and the product
name/part number.
A binder containing the Material Safety Data Sheets (MSDS) for
BMW NA distributed Chemical Products was sent out
with Parts Bulletin 99 05 97. Questions on the use of this
information may be directed to the Safety and Health
Officer (201-307-3623) or to the Parts Consultant Group (800-272-0202).
Location - inside of a building whenever possible or covered
parking lot (especially convertibles).
Replace engine oil and filter after engine reaches operating
temperature. Run engine several minutes after replacing oil.
Engine oil must be replaced every 12 months. Factory engine
oil (in new cars) can remain in the engine up to 12 months.
Check/correct electrolyte level in battery cells.
Disconnect battery ground lead to avoid discharging battery
through current draw of electrical equipment. Or, switch off
battery main disconnect switch (if equipped).
Recharge battery according to S.I. Bulletin B 61 07 88.
Inspect undercoating for damage and repair as necessary.
Inspect wax coating in engine compartment, on engine,
underbody and axles. Repair as necessary.
Operate air conditioner monthly for 10 minutes in order to
lubricate the seals and the expansion valve. Note: The air
conditioner will only work at temperatures above 37°F/3°C.
Pre-Delivery Cars
Replace brake fluid if car has been parked outdoors longer
than six (6) months.
Fill the vehicle fuel tank with fresh fuel in order to prevent
condensation inside the tank (applies only to metal fuel tanks).
Check, and if needed, correct the coolant level and
concentration of long-term antifreeze and corrosion inhibitor.
Apply brakes to dry the brake discs of any moisture and spray
them with a corrosion inhibitor. Spray the complete brake
assemblies after parking the car at its final storage location.
Do not apply the parking brake. Brake linings could seize
when the parking brake is applied for an extended period of
time. Rather, engage first gear (manual transmissions) or
“park” position (automatic transmissions) to hold vehicle
stationary.
Increase inflation pressure on all road tires to 50 psi.
Thoroughly clean the entire car, including underside, engine
and engine compartment.
Exterior Finish
Repair any damage to the paint finish. Wash entire vehicle
exterior with BMW Car Wash Shampoo (Part No. 82 14 9 400
129) or equivalent. Polish painted and chrome finishes with
Car Polish Cream - 3M Part No. 6055 (former BMW Part No.
82 14 9 400 131) or equivalent.
Polishing the vehicle with abrasive cleaners and/or cleaner
waxes may have a detrimental effect on the appearance of
the paint. Waxing of Paint Sealer treated vehicles may still
be done, but only if non-abrasive cleaners or non-abrasive
cleaner-waxes are used.
Wax painted and chrome finishes with BMW Car Wax
(Part No. 83 12 9 408 527) or equivalent.
Wax painted and chrome plated parts if storage period
is 12 months or longer. Dewax and rewax cars every six (6)
months if stored outside.
Check convertible top for damage.
Conversion Factors:
Liters in US Gallons x 0.264
US Gallons in Liters x 3.785
Liters in US Pints x 2.113
US Pints in Liters x 0.473
BMW P/N Description/Application 3M P/N Wrth P/N Loctite P/N
81 22 9 400 208* Lubricant/Contact Cleaner Spray
Stops electrical and mechanical faults due to water, moisture,
rust, dirt and friction. Colorless, neutral, free of grease and silicone,
suitable for all applications.
Examples: Stops moisture on distributor, generator, ignition coil,
starter, spark plugs, coils, relays, contacts, etc. Prevents metal parts
from corroding. Stops rubber and plastic parts from aging
prematurely. Applications: from -50oC to +150oC.
89360/1 24379
81 22 9 400 229* Hand Cleaner
Removes stubborn stains and grit without attacking skin.
Contains
special skin protectant. Does not clog pipes.
893900 25108
81 22 9 400 720* Molybdenum Disulfide (MOS2) Spray
Loosens rust, eliminates squeaking and similar noises,
prevent rust seizure. Displaces water on ignition components
to allow quick starting. Insulates electrical systems against
moisture and stops corrosion. 8876 24378
81 22 9 407 138* Stain Remover
Removes tar, oil and grease stains from seat covers, leather
upholstery and painted plastic components.
89024
81 22 9 407 174* Bearing Grease
A water repellent high-pressure grease for lubricating flywheel gear
rings, starter motor pinions, etc., and also as an acid-proof grease
for battery terminal posts.
893530
81 22 9 407 301* Loctite 574
Anaerobic, silicone sealant for aluminum flange surfaces. Provides
instant sealing when flanges are assembled.
893574 24018
81 22 9 407 388* Adhesive Remover
Removes all residual or excess adhesive, sealing and coating
compounds, wax, grease or oil films from painted and plastic
surfaces, i.e. before installing front or rear spoilers and décor strips.
8984
81 22 9 407 394* Loctite 380
Black cyanacrylate adhesive for joining metals, rubber, PVC.
8155 893 4103 38050
81 22 9 407 524* Contact Cement
Powerful adhesive for leather and leatherette, rubber moldings,
seats, rubber mats, noise-absorbent materials, etc. Has good heat
resistance and does not attack paint.
See S.I. Bulletins B 54 02 95 and B 54 01 93 (3754).
1357HP
81 22 9 407 629* High-Adhesion Lubricant
Long-life high-adhesion lubricant for clutch and brake linkages,
spring struts, stabilizers, idler levers and pivots.
8878 20029
81 22 9 407 711* Universal Lube Spray
Colorless lubricant with high lubricant content. Eliminates squeaks
and grating noises from spring seat bases. Lubricates door stops
and locks, seat adjustment mechanism, etc. Resistant to
8878 893106 20029 temperatures between -50oC and 120oC.
*These items are no longer available through BMW NA Parts Department.
The above alternate suppliers can be contacted below:
3M Wrth USA, Inc. Kem Krest, Inc. (Loctite)
19460 Victor Parkway 93 Grant Street 1919 Superior Street
Livonia, MI 48152 Ramsey, NJ 07446 Elkhart, IN 46515
(800) 521-8180 (800) 526-5228 (800) 285-5917
Group Description, S.I. Bulletin Product Name, Source Telephone
11 Engine Oil, SAE 5W-50 “Syntec FSX”
Castrol Inc., Piscataway, NJ
732-980-9100
11 Oxygen Sensor Lubricant Bostik “Never-Seez” NSBT-16
Bostik Findley, Middleton, MA
888-603-8558
11 Intake & Vacuum System Leak Detector
S.I. Bulletin B 11 03 92 (3500)
“LiquiMoly (Lubro Moly) Motor Lecksucher” 2021
W.A.W.D.
800-477-9293
11 Cold Weld Epoxy “J-B Weld”
J-B Weld Company, Sulphur Springs, TX
903-885-7696
13 Loctite 290
Throttle Housing Fasteners
S.I. Bulletin B 13 06 91 (3440)
“Loctite 290”
Kem Krest, Inc., Elkhart, IN
800-285-5917
18 Copper Paste Exhaust System Joints
S.I. Bulletin B 18 03 89 (1954)
“8945”
3M Automotive Trades Division, Livonia, MI
800-521-8180
23 Synthetic Transmission Fluid “Mobil SHC 630”
Mobil Oil Corporation
800-582-3645
34 Brake Component Lubricant
S.I. Bulletins B 34 02 94 & B 34 05 98
888-603-8558
36 Loctite 638 (green)
Affix wheel hub covers
“Loctite 680”
800-285-5917
36 Loctite Cleaner 755
Loctite 242
M5 Wheel Covers
S.I. Bulletin B 36 03 90 (3182)
“Loctite Cleaning Solvent 755”
“Loctite 242”
800-285-5917
41 Structural Adhesive
S.I. Bulletin B 41 01 95 (4150)
“DP420 Epoxy Adhesive with 3M EPX Applicator”
3M Industrial Tapes and Specialties Division,
Livonia, MI
800-521-8180
54 Renax GL1
“Poliplex #1”
Fuchs Lubricants Corp., Harvey, IL
800-323-7755
61 Rubberized Super Glue “893 4103”
Wrth USA, Inc., Ramsey, NJ
800-526-5228
62 Contact Cleaner Spray
IC Acoustic Transmitter
S.I. Bulletin B 62 04 92 (3539)
“CRC QD Contact Cleaner Spray 5101”
CRC Industries, Warminster, PA
800-272-8963
63 Silicone Gasket Material
Turn Signals
“Permatex Form-A-Gasket 6B-80627”
800-285-5917
Page 5 of 5
S.I. Bulletin B 63 05 91 (3313)
64 AC System Disinfectant
S.I. Bulletin B 64 08 91 (3373)
“Airguard”
J.J. Products, Inc., East Orange, NJ
“Airsept”
The Auto Doctor, Tucker, GA
800-654-2356
404-662-6778
64 AC System Treatment “893540-U”
800-526-5228
97 Brushable Seam Sealer
Seals spot-welded, riveted, or bolted
seams and joints. Brushable consistency
remains flexible. Retains brush marks
appearance.
“8901021”
800-526-5228
97 Body Seal, Beige
Underbody Seal, Black
Permanent, flexible protection against
stone chipping damage. Fast drying and
paintable.
“0892091 U”
“0893075 U”
800-526-5228
97 Seam Sealer, Grey
Fast drying, paintable, silicone-free
sealant for special spray gun application.
“0893228 U”
800-526-5228
99 Paint Cleaner “Machine Cleaner 1” and “Hi-Tech Cleaner 2”
Meguiar’s Inc., Irvine, CA
800-854-8073
99 Machine Glaze “Mirror Glaze 3”
800-854-8073
99 Paint Sealer “Sealer and Reseal Glaze 7”
800-854-8073
99 Paint Swirl Remover “Hi-Tech Swirl Remover 9”
800-854-8073
99 Paint Carnauba Paste Wax “Hi-Tech Yellow Wax 26”
800-854-8073
. . . and for your clutch :
3.0 Other Operating Fluids
Clutch Component Grease
Use UNIREX S2 (replaces Klueber Microlube GL 261) for the
lubrication of splines on the transmission input shaft,
lubricating groove of the clutch release bearing, piston rod
sleeve, clutch master cylinder and front push rod of the
UNIREX S2 Grease BMW Part No. 83 23 9 416 138
See S.I. Bulletin 23 01 99 of 2/99.
As of 11/93 the clutch release bearings are available as
a replacement part which have plastic sliding sleeves
instead of aluminum. Such updated bearings should
not be lubricated at all. This applies to all models with
manual transmission except for 8 Series models.
See S.I. Bulletin 21 01 94 (3953) of 1/94.
'64 R27 250cc #383851 18,000m
