Noobie question: Turn signals don't work--what could it be?
norma
bad fuse or fuse holder (corrosion)
poor grounds/sockets at the bulbs (unlikely that all 4 would fail simultaneously)
flasher unit suddenly died (check to see if 4 way flashers work--they both use the same flasher)
4 way flasher switch went bad (turn signal power goes thru the 4 way switch)
turn signal lever has gone bad
etc etc...I'd check the fuse first: #5 on 6 fuse car; 5 & 6 on 12 fuse roundies; 6 on squarelights
cheers
It might be the 4-way flasher switch. This happened to my square light car. The switch is a tie point for the whole turn signal system. The switch wears out mechanically and the circuit opens. Try actuating it a few times. They are available new.
I first owned a 2002 in 1975.
Okay, it's not the fuses and the 4-way (that controls the hazard light, right?) seems fine because the hazard light works. What's next? Connections? This is bugging me. I checked the archives but I need more help. I'll check the manual too. Thanks.
