door outer trim clamps
robsanab
I took the door's outer trim (#3) off. The clips/clamps are shot and just fell apart and away.... I can't tell if I need item #7 or #10 (both called "clamps"). They are fairly large complicated stampings that fit into the trim to clamp to the door.
They look more like #10 than #7, but item 10 looks like it's associated with the inner weatherstrip #4 (i don't THINK so)... YET it is correct that there were 4 per door (per RealOEM)... item 7 just shows an X for quantity. Can anyone verify? At 3.50 a piece i want to be sure.
Also, per my last inquiry the only suggestion for NLA item #9 was possibly a felt from an old mustang.... i looked at my '66 and it appears not to be U-shaped... but it might work if I glue it in... for that matter any similar felt could work. any other suggestions or if I go the mustang route what to glue it with? OR is this felt even required since I do have a new item 8?
thank you
{option}[/img]
Rob
1966 Mustang vert - 5.0EFI/AOD & mods
1975 '02 - the typical upgrades (my 'new' car)
