megasquirt VR sensor help
highboostin2K2
No problem at all. I have the same problem. I mounted my toothed wheel 180 degrees offset, just like you. Just switch the coils, or switch the leads from the EDIS to the coils.
It's a wasted spark system. Each coil fires a spark every rotation of the crank, and each coil is 180 deg offset from each other. So you either need to swap the coils, or fool the coils into thinking the first is the second and vice versa.
email me if you want me to talk you through it.
John Capoccia
Sierra Madre, CA
