How do you tune 40doce webers side drafts with wideband?
fast2002
Well, ultimately, you strap the thing to a dyno,
and then find both maximum horsepower AND then
efficiency, and then tune to a nice, drivable compromise somewhere in the middle.
But that's expensive. What I do is use the wbo2 to see what's going on
at different rpm's, load ranges and throttle positions.
When I'm driving hard, I usually target 12.5- 12.8:1 for power- you can go
richer, but I've never seen any real hp gains, and the plugs read rich below
12.5.
Now it gets trickier- I use it at cruise and 'round town just to make sure
the mixture's in the ballpark. It takes a bit of jetting to get them to
behave at low throttle openings, but they'll do it.
The best use I've found is for finding problems- for example, if it stutters, what's
the mixture doing? If it bogs, likewise...
You really need a book on the Webers, because there are a LOT of jetting
changes you can make to the progression and idle circuits- the wbo2 will
just confirm the effects of the changes. The books (Pat Braden is good, Haynes
is OK) detail the workings of the different circuits- and pictures are invaluable.
And start with the venturis (chokes)- if they're not right, (i.e. 32mm or smaller)
getting drivability around town will be harder. And any choke change causes
a complete change in all the other jetting ranges...
hth,
