Help Identifying These Parts . . .?
SeanH
So I just received these bushings from Ireland and I'm having trouble figuring out which is which.
Would anyone mind telling me where these groups belong on the car?
This missing bushing from Group D I've already installed on the upper part of the front control arm. It fit well, hopefully that was correct.
It seems like the same sized bushing should be used on the lower part of the control arm as well, but I only have two in this size. Do I have this wrong, or have I recieved the wrong parts?
I appreciate the help!
Photobucket
A = differential bracket to body
B = rear control arm to rear subframe
C = strut rod to front subframe
D = inner control arm to subframe
E = strut rod to outer control arm
Bret @ Glass from the Past
www.caferacingparts.com
971-207-2824
So group E should be installed on the lower control arm (the part that meets up with the ball joint) right?
When I put that part in before it seemed to be too short, but the diameter was correct.
Sorry to be so thick-headed about this. Just wanted a little confirmation before I got it all plugged back in.
Les, I replied to your email :-)
