Can anyone explain the purpose of the air pump.
oldbimmers
Are you planning on using the air pump? if so, Don't.
There are 2 theories regarding the air pump -
1 - it pumps clean air into the exhaust to make the ppm of harmful exhausts go down so it will pass emissions
2 - the added air makes and unburned fuel ignite and burn off in the thermal reactor
I dont know which is true - but both are useless.
Patrick Sloan
1975 inka 2002 - 2375719
1991 325iC
2001 325i
to keep them cooler. The early fix for emissions was to lean the crap out of the engine, frying the valves. The pump and the infamous 'gulp' valve were the first of several bandaids those lovable Germans used.
Yours for folklore and urban legends
John N
I have limited experience with air pumps except that they had a terrible habit of making 70's GM cars sound impolite and terrribly restricted. I vaguely recall someone with a Camaro attempting to modify his airpump so that it supplemented his normally aspirated system. Kind of like a poorman's supercharger.
The concept sounded good, but I do not believe it was successful.
Good luck.
and don't use much power. They merely pump some fresh air into the exhaust manifold; they don't 'restrict' anything.
Assuming you're doing this to a pre-1976 car in California, you don't strictly need the air pump.
A non-tii alternator mounted non-tii style is fine, and it will be more accessible for service.
Curt Ingraham
1972 2002tii, 1976 2002
Improved 2002 Radiators
