Which electronic ignition?
albawhore
All stock? The Pertronix is good value- for- money.
The Crane 700 has worked flawlessly in Jenn's car for 8 years,
my street points/MSD combo is a bit sloppy,
and the P-tronix/MSD 6AL in the race car is rock solid.
fwiw.
273 cam, 32/36 has to pass smog and I am probably going to give it to my daughter when she turns 16 so I want reliable and easy to trouble shoot. She doesn't live anywhere near me so I will not be able to work on the car once she has it. Hopefully I will poison another youth with the sickness we share though.
JB
Justin
'75 o2 blog
00' 4runner (fishin machine)
If you want an electronic ignition you have to chase the other options like Crane or the MSD.
I have the Crane XR-700 with a red coil and red coil resistor. I have ran that set up for 4 years with no problems. I even have the control box in the hottest part of the engine bay and it has peformed flawlessly.
Crane's tech support folks are very helpful if you stumble on installation. I used them to determine if a resistor was needed for the red coil.
1972 2000tii Touring #3422489
FAQ member #5
