Has anyone ever successfully replaced one of their front quarterlights without taking all the glass out?
The tab on the base of #3 in the attached photo has broken off of mine, just wanted to see if I should start looking for the whole track and quaterlight frame, or if I will be able to jimmie another one in there without breaking the tab off again. I'm hoping I can just slide another #9 and #3 plus the glass in there and be done with it.
Not sure why it broke, just fell into my wife's lap when she was on her way to work one day.
Thanks
Mac
whew, thought I'd never get that pic up...
Open the quarterlight and then remove door panel to get access to remove the hex bolt holding the "tab" to the mechanism. You should be able to jiggle the window up and off the pivot. Fitting the new window is reverse procedure. #3 is the window seal and will remain in place.
Les
'74 '02 - Jade Touring (RHD)
'76 '02 - Delk's "Da Beater"
FAQ Member #17
