Making progress,question about door cards
While everything may work fine without it, I think I have discovered why they are there.
I did not put mine back, in part, knowing I am going back inside the doors again (and again) to fix a few more things.
On the passenger side, the window crank has taken a little bite out of the vinyl.
I suspect the springs are used to take up the 'slack' in the panel in a way that insures a lack of interference.  I stuck the fuzzy side of some Velcro tape to the back side of the handle to protect the vinyl.
VW used them as well, but the spring is a little heavier.  Actually, my '72 Suburban uses them too and I've taken some other trucks apart, so that could be a GM spring on the right.
https://www.ebay.com/sch/i.html?_from=R40&_nkw=64-72+gm+door+window+regulator+springs&_sacat=0
https://www.google.com/search?q=Volkswagen+beetle+door+window+crank+springs&oq=Volkswagen+beetle+door+window+crank+springs&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigATIHCAIQIRigAdIBCTE0NTI2ajBqN6gCALACAA&sourceid=chrome&ie=UTF-8
I bought these for the heck of it, to see if the springs would work. They are almost identical size as the vent window spring.
Ensun 11127547058 Crankcase Vent Valve PCV Pressure Regulating Valve (Pack of 2) https://a.co/d/besdgKg
The conical spring is similar to what is used on old GM door panels.
Retro-Motive Inside Window Crank Tension Springs Fits 50-89 Chevy (Qty-2) #825 https://a.co/d/dSFVMtH
I am also in the camp of installing the springs behind the door panels.
Edited by bergie33
Karl B.
2003 330i ZHP 6-spd
2011 328i xDrive
