Exhaust in cabin
Yale E
I tend to put a lot of miles on my cars and also it’s not unusual for me to have a car worked on for years. And that certainly has been the case with my turbo. Now it’s at a friends garage in North Cal. A few years ago, before covid,  I had the car worked on in Southern California. That’s why the car was out there, though I live in NYC. It was never fully fixed in south cal so it ended up with a 2002 specialist my friend, (who is a porsche mechanic) knew. It’s seems the car is now finally sorted and my in friend moving back to his garage, noted to me that he’s getting exhaust fumes in the cabin. I remember that was always the case with the car. And when I had it at sportscar restoration in ct, they said this happens with 02’s. My west coast friend heard otherwise and thinks it could be because of the spoiler. So dear tubo-ites. What is your experience?
Start off by looking at the trunk seal, that is where most '02's leak.  The other possibility is the connection between the front down pipe and the center exhaust pipe.  If you have a leak there and you don't have the big foam plug around the shifter in the floor it leaks quite badly there as well.
1970 1602 (purchased 12/1974)
1974 2002 Turbo
1988 M5
1986 Euro 325iC
Not inside the car.  If I stand behind it while it is warming up it's definitely rich but other than that I don't get any exhaust or fuel smell.
1974 2002 Turbo
1988 M5
1986 Euro 325iC
You might try blocking the air outlets at the base of the back window (under the trunk lid)  sometimes if you have the vent windows open you can have a back flow through them.
1974 2002 Turbo
1988 M5
1986 Euro 325iC
Thanks Pre, appreciate the thoughts. As someone mentioned, this situation happens mostly with windows open. Which of course could be that there is more ingestion of fumes from various places because the window is open.
It is a common '02 problem and not limited to the Turbos.  Are the vent tubes hooked up inside the trunk?  A lot of cars that have been restored are missing these or they failed to hook them up correctly
1974 2002 Turbo
1988 M5
1986 Euro 325iC
Good point. Mine are missing in both cars.
January 30, 1973 Agave tii
April 24, 1974 Chamonix Turbo (German delivery)
