clashcity74 Posted October 31, 2022 Share Posted October 31, 2022 (edited) Hi All. I have a 73 that the previous owner installed seats from a Turbo Beetle. I've bought a set of E21 Recaros to replace these. Primary issue is the VW seats are bolted into the floor and the original seat mounts are gone. Are there any recommendations for folks that can undo the seat install and fabricate some mounts for the Recaros? Thanks Edited November 1, 2022 by clashcity74 Link to comment Share on other sites More sharing options...
layers Posted November 1, 2022 Share Posted November 1, 2022 Hi-- I recommend Superior Upholstery on Erickson Rd. in Concord. But I suspect that's a lot farther than you want to drive. I found that Jose does good work at a reasonable cost. Link to comment Share on other sites More sharing options...
clashcity74 Posted November 1, 2022 Author Share Posted November 1, 2022 Hi Larry - Thanks for the info. That might be a bit of a haul but I'll keep in mind if a few other options don't pan out. Link to comment Share on other sites More sharing options...
2002iii Posted November 2, 2022 Share Posted November 2, 2022 Easiest thing to do would be find someone parting out a car that you can cut the factory seat mounts out of. Then you just need to have someone weld them into your car. The e21 Recaro brackets bolt on to the factory sliders. Link to comment Share on other sites More sharing options...
clashcity74 Posted November 2, 2022 Author Share Posted November 2, 2022 18 hours ago, 2002iii said: Easiest thing to do would be find someone parting out a car that you can cut the factory seat mounts out of. Then you just need to have someone weld them into your car. The e21 Recaro brackets bolt on to the factory sliders. I hear you. You know anyone with a parts car?! Link to comment Share on other sites More sharing options...
