Rebuilt Motor - larger pistons, 292 cam
RedShred2002
Price: $4900
Description:
Racing/Street Engine BMW 2002
Top end and bottom end are newly rebuilt and zero miles.
New Pistons, rings, rods, bearings.
Ireland engineering 10.5:1
The head was redone with larger intake and exhaust valves.
292 degree Ireland cam.
Also all the timing gear, chain, tensioner guide etc. all new.
All new genuine BMW gaskets like head gasket kit
Down pipe $100, exhaust manifold $75.
Fly wheel $100
Used Weber 32/36 $100
Intake manifold $150
Rebuilt starter $100
New plugs $12
New wires $50
Rebuilt distributor with new points, condenser, cap etc. $200.
Used coil $40
New oil Castrol GTX 10-40 $25
These are just accessories that are attached to the engine to make it run and make it a drop in and go. No need to swap anything except highly recommend dual side draft carbs to exploit full potential of this engine.
Used:
Down pipe. Exhaust manifold are used.
Intake manifold is also used. Weber carb 32/36 is used.
Has a used fly wheel also.
Total is $4900 for everything
Kevin Erdman
1976 Verona 2002
mostly original
  • 4 weeks later...
