Aussie02 resto
aussie2002
Hi all. I thought it was about time I shared some pics of my 1969 2002 resto. Full bare metal and now being built up. Loads of challenges but going pretty well. e4c774ddd8f90d7dd67714e4187e1268.jpg4b50512b4cfb4a3bce063dcbaf309c2c.jpgf0dc8227952ee6c5baf1c4f3f8e2984a.jpgce62df35dddd4318600d1f2387576f68.jpg54fe4d4193ad65025988282605dd2471.jpg9926d638ec8b31063ed08c3a75665bb7.jpga312fd515067f3ec28f3758444a76dfe.jpgf69d7c0207807f26acf05755f5cb5f01.jpga80e69871db641d115f860c4c75c8bec.jpg57a98d05e0b81d0bc6f4a2861055762e.jpg
Lots to do. Some details
Rebuilt harnesses
Rebuilt heater box new core seals and motor
Rebuilt engine
IE front and rear springs, sways and shocks
All nuts and brackets etc stripped primed and painted
New brakes
New brake lines
Donor car looking a little worse for wear now
Gear box next in line
Front and rear subframes stripped and rebuilt.
Any observations and comments welcome
Cheers.
Nice to see another 69 getting restored!  It's a lot of work but you will be happy in the end.  What is the VIN?  I see 6 fuse hole in the fenderwell, but a later Roundie gauge cluster.  Before you go any further, are you going to upgrade the seat belts? I recommend adding a threaded fitting to the b pillar so you can use retractable type 3 point belts. Are you going to keep the wiring stock or adding some relays for the lights?
Well spotted!! Vin 1650781
B pillar inserts done.
6 fuse is a pain but I can work around that. I’ve added a new loom and relay for lights but rest of wiring is stock.
I’m not sure yet how compatible the cluster is but mostly my testing it seems ok.
Also converting to dual circuit brakes.
Nice to see another Aus car getting some love. What city are you in? I'm in Brisbane.
Sent from my E5823 using Tapatalk
The early cluster (silver dollar type like in a 69) has different length mounting studs on the back compared to the 71-73 black faced cluster.  Make sure you test fit the one you want to use before committing.  The 3-piece dash may not allow the black-faced gauge cluster to sit far enough back to secure the knurled nuts.
My 73tii with black faced cluster and 2-piece dash
Silver dollar type cluster from my May 69 2002 with 3 piece dash.
3 minutes ago, aussie2002 said:
That’s great info. Thanks. Does the 2 piece dash from a 71 fit into a 69? I can therefore use the matching cluster?
I believe you can use a 2 piece dash in your car.  Just have to get the correct heater controls and dash cluster.  3 piece dash has different heater lever control mounting.
Oh wait - your car is European. Assume it has the chrome pieces on the bottom of the lower section?
Edited by jgerock
It’s a RHD car. I’ve got a mix of pieces for the bottom half but the two piece dash is likely what I’ll use. I think the 69 loom for the heater is different to what is needed for 71 heater. Perhaps only one speed. So I’ve got to work through that also.
