WTB: rear hub/flange stub axle
pklym
Forgive me if my part names aren't quite right. I cannot get my passenger rear hub off to upgrade to e21 drums. I already have warped the hub with my puller and anticipate I will need a lot more heat and a real big hammer. Accordingly, I will be needing to replace the hub/flange and I assume I will end up with a mushroomed axle.
Need parts shipped to 97217. The sooner the better!
Thanks,
Peter
I have a stub axle, which is what I suspect you're looking for--the part that connects the outer CV joint to the rear hub through the trailing arm. If you're also planning to replace the 2002 rear hub, I have that as well. You can reach me via PM or email to grice dot mulligan at gmail dot com.
williamggruff
