Anyone Familiar with this Flywheel on ebay?
goofycarp
Quote
which is about 10x stronger than cast iron which the factory one is made from
which is about twice as strong as cast steel, which the factory one for the 2002 is made from.
Having stuck a stock one on the lathe, it's not fragile.  And it is steel.  But RH's material's another notch stronger...
RaceHead has a good rep.  Try it and see!  The bellhousing blankets are cheap.
I once saw a GTV that had the bellhousing removed forcibly by the flywheel.
I peed my pants right then and there.
But then I went and did what you see below.  Because racecar.
One thing to consider.
The stock cover plate weighs about as much as the stock flywheel.
So while you can reduce rotational inerta by several pounds on the lathe,
there's still a lot of MASS in the assembly.
I ran a 7" clutch on the race car for a very short while, and it gave me a total nerbie.
It's REALLY different, in a good way for the race car.  Made me want to lighten the crank, too
(I never did)
On a street car, the stock clutch has its advantages in durability and un-stall-ability.
