Vacuum Advance Connection
borgpj
On our 1973 Sahara project car, we have a vacuum advance distributor and a Weber 32/36 carb.  The carb has one vacuum port that, I believe, originates above the throttle plate, so that vacuum would only be generated when the throttle opened.  Per diagrams I have seen, I believe this port is designated for the EGR control valve.  To the best of my knowledge, I believe the vacuum advance connection for the distributor needs to be made to a port below the throttle plate, to tap into manifold vacuum.  Can anyone with an unmodified '71 to '73 2002 verify or clarify the proper vacuum advance connection point?
pb
On this board somewhere is a reference link to the Weber tuning manual.  Vacuum advance port function is explained there and why it is located slightly below the throttle plate.
It's confusing.  Here is what I am basing my thoughts on:
http://www.bmw2002faq.com/topic/67452-weber-3236-smog-legal-vacuum-diagrams/.
In the diagrams, apparently from the Redline Weber site, the 72-73 cars with the 32/38 Weber carb pull spark advance from the intake manifold, not the carb port.  It looks like the carb port tap is used for the EGR valve.That's why I wanted some 2nd opinions from other Weber users with vacuum advance ignition.  It's possible that a lot of folks have their connections done incorrectly.
Also, here is a great discussion of vacuum advance functionality (admitedly talking about Detroit V8 engines, but still applicable).  Read on...
http://www.460ford.com/forum/showthread.php?t=117504
pb
