Megasquirt Timing With Edis Trigger Wizard
austinmf
Running EDIS with the megasquirt II (turner studio). I am about 8 degrees off on the tooth vs VR sensor. I am almost at the 10th tooth. I subtracted 8 degrees (estimation) and put a timing light on the engine. It is 0 degrees at TDC and the trigger wizard is showing 16 degrees. No matter what I do it will not change from 16 degrees. Running the timing gun up to 25, the hash mark on the flywheel pops up.  the trigger wizard is 16.
I am supposed to make the trigger wizard match the timing gun number but when I attempt to boost the number, the car runs like crap and dies.  Any ideas on how to make it match the timing number?
FOR SALE-----74 2002tii 2782194 Turkis, Megasquirt, Korman road sport springs, Bilstein HD shocks, 13" FPS Bottle Caps
Try changing the tooth #1 angle (deg BTDC) in "Ignition Options" This may have a different menu title depending on the version of tuner studio your'e using.
Too many cars.
hmmmm  Great point!   I forgot that was there!   Thank you!!!!
Just figured out that the trigger wizard changes this value....
post-40420-0-62774500-1387430953_thumb.p
post-40420-0-31907900-1387463118_thumb.p
Edited by austinmf
Austinmf
You said you are running EDIS, but the thumbnail shows that you have selected "basic trigger"
I also noticed that you are not using the latest version of Tuner Studio. The update is free.
Here is a good link that might help you.       http://www.extraefi.co.uk/MS2_Settings.html
Too many cars.
This is actually a dummy set up on the mac for my JIMSTIM and testing.   My actual is set for EDIS
I went through Colins megasquirt set up and copied his verbatim.  :)
I ended up purchasing the full blown for the autotune... and the version upgraded yesterday for me.
My issue is getting the software to sync with the timing light.  I am guessing to do it at 1500 and subtract in the wizard until the value matches the timing light.  I was under the impression that the value in the wizard changes as you plus or minus the value but I think the engine advance changes and you adjust via the timing light.
I am off a tooth too.... I have an 02AGAIN trigger wheel and VR sensor holder.
Thank you for your help!!!!!
