76 2002
bimmerboi
There is no rub on the rear at all. The front wil if I get on it in a turn but not much. If I hit a bump the front wil tap. I'm running 205 50 15s. There is a slight rake to the car.
What I did was put my spacer back under the front strut bearing. This brought the front up about .5 inch. No rub, no rake. I should have rolled the fenders but had it painted without thinking.
Where did you get your rims? You car looks very good! I like the clean lines.
There is no rub on the rear at all. The front wil if I get on it in a turn but not much. If I hit a bump the front wil tap. There is a slight rake to the car.
I did you get rims? You car looks very good! I like the clean lines.
Im planning on rolling my fenders and then lowering it. I got the H & R springs so that should be about the same as the IE stage 1 springs. But your stance is exactly what i want. What size of tires are those? I have 195/50/15 right now but i want to go to a 195/45/15.
