Thanks Slavs, do you know where I can get a new set (pressure plate, clutch disk) of this size? as the ones I found are either 215mm or 228mm.
Do Good Attitood
I was wondering if the difference of 15mm between that clutch on ebay 200mm and the usual 215mm does really matter? or is the later applicable as well?
Do Good Attitood
Here are some e-bay links for the clutch parts (No affiliation to me, I just noticed them while browsing):
http://cgi.ebay.com/ebaymotors/BMW-1500-1600-1600-2-1600TI-1800TI-CLUTCH-DISC-epe-/380339526915?pt=Motors_Car_Truck_Parts_Accessories&hash=item588e009d03
On the 2nd link they incorrectly labeled the pressure plate and disk as 215mm, but this type of pressure plate was never made in this size for the BMW. It was only made in the 200mm configuration. The 215mm pressure plate was made only in the dighpram style and not the 3 prong style pictured in this add. So it is best to contact the vendor and ask if the pictured item is the actual item for sale. And if so, ask the vendor to read the numbers stamped on the parts. They should all read FS 200K or something containing 200.
IF you have the original 6 hole crank in your engine, you may only use the 6 hole flywheel and the 200mm pressure plate and clutch disk.
http://cgi.ebay.com/ebaymotors/BMW-1600-2002-PERFORMANCE-PRESSURE-PLATE-AND-DISC-215mm-/150562879016?pt=Motors_Car_Truck_Parts_Accessories&hash=item230e3f3628
