Distributor vacuum line routing
Tangmere
Hello FAQ'ers, newbie here with manual on the way.
I am having a stumbling problem with my newly acquired 75 Solex 02. I need to set the valves, adjust timing, reset the pertronix to make sure its on the money, have done plugs wires and cap and rotor so far. My question is, its falling hard on its face on initial acceleration, and i noticed that the distributor wasn't hooked to anything on the large diaphragm side, and connected to a sort of vacuum sending unit on the firewall, which wasn't hooked to anything. I have searched on the forum, but being relatively new to 02's i haven't been able to find what i am looking for. Where does these two ports plumb to? Both to carb vacuum? I think that might defeat the purpose, i suspect one is retard (like me right now) and one to advance?
Thanks for your response, this forum has been a wealth of info, and is the perfect example of what a enthusiast community is.
Yeah. You would benefit from connecting the advance side to the base of the carb, passenger side.. (right guys?) I can't help with which is the advance, but I'm gonna guestimate that its the nipple on the passenger side of the canister...??
(O=o00o=O)
Ok, i left it attached to the retard side (no diaphragm) and it seemed to work better this morning. The car now has simply "ok" pull up to about 5500 rpm. I will try switching it and adjusting the idle and see where that leaves me. Any idea on the port that would be vacuum on deceleration?
Thanks again!
you could have a EGR valve that's not closing tight
internally causing a huge stumble/vacuum leak
you can test for this by applying and taking away the vacuum to
the EGR and hear a click, as well as the motor will nearly stall
out when the valve opens
and of course a carb with inop accel pump, clogged idle/primary
circuit will cause your problem
'64 R27 250cc #383851 18,000m
Hmm.. ok, so looking at the diagram and my car, the airpump is not on the car. That being said, where would the EGR valve be located? I tried to follow the diagram, and i think i have it pretty much correct, looks to be a faulty accelerator pump in the ol solex... next question is, if the tag is broken off the top of the carb, how do i know which solex it is to get a rebuild kit, or is there only one?
Thanks!
