121 cylinder head fuel pump mount question (for a tii)
jgerock
Engine # 2762332 pulled from a 72tii.
There are (2) bolts installed where the fuel pump mounts to the head (for a carb'd car), but there isn't a hole in the block. Was it normal for the bolt holes to be present in 121 heads?
My 73 with E12 head does not have the holes for the bolts.
You're too quick - I didn't see that last picture before my response:
What's the date stamped into your 121 head? Mine looks like June 72.
This one has aluminum runners. Not sure if they are original though
VIN 2761332, plastic runners - never been messed with, has a pair of studs (just like the carbed cars). The plenum has an extended, cast in, support that bolts to the studs. ....... never paid attention to that before. Glad you pointed it out to me. Learnin' sumpin new every day. ; )
mac.
The late '71 build Tii motor in my garage has those as well, and this one had been converted to aluminum runners as well.
Thanks Jason - do you know the date stamped into the KF injection pump? The one I'm working on now looks like August 1971. The date code is stamped on the engine-side of the pump (very difficult to read with the coolant hoses installed).
Here's the one from my '73
