Timing question
nbristow01
Go the new carb on, car runs ok, I can tell by the feel that timing is off. When I turn the car off it stumbles and won't die. i have to kill it by releasing the clutch, then a poop thru the carb. So with that said do you guys know if I need to slowly work the dist clockwise or counter? i don't have a light. i am trying to get it running decent enough to get to Brad fenn's in the mornign so he can work a little magic on it
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
If you're running a 32/36 Weber, the after-running can be fixed with an idle cut-off solenoid. It screws into the primary idle jet boss and is powered from the key on/off position.
