Turn Signal Cancel with Momo Adapter
I used the momo adapter #0155 for a momo steering wheel upgrade , but my turn signal no longer will cancel. There didn't seem to be the same kind of tab on the bottom of the adapter as was on the previous steering wheel (off a 320). Is my adapter missing something?
Thanks
........ yes - a TAB is missing You've already diagnosed your
problem.
can you post a photo of the Before, and After hubs
for further consultation ?
'64 R27 250cc #383851 18,000m
The MOMO hub you have is the correct part. Often times the cancel tab(part#32321118825) will come off when you pull the stock steering wheel. Check the stock steering wheel, remove it and reinstall it on the shaft.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
