Third brake light photos
3elements
Got this third brake light installed yesterday. It's from an early '80s Toyota (Cressida or Corolla, I wasn't paying that much attention) at the local PNP.
The angle to the window is perfect. I built a base of MDF to get it the right height, then covered that with a strip of rubber. Can't see it throught the rear-view, but it looks good from behind.
Steve E.
www.theportabledad.com
1974 Sahara 2002
1974 R75/6 (Sold!) :(
This is a fertile land, and we will thrive. We will rule over all this land, and we will call it…This Land
Looks really good
That's something I would like to do to my car. (1976)
How hard was it to wire up?
Do you actually patch in the wires at the brakelights themselves in the rear of the car or do you patch in the wires up front?
Maybe a better way of asking you this is just to say "howd ya do it"? : )
Morris
Morris,
Real easy. Ran the wires through an old speaker cutout into the truck, then along the left side with the existing wire bundle. Tied the hot wire into the hot at the left rear tail light, and ran the ground to the existing grounding point beneath that light.
Be sure to test your wrecking yard brake light before it's in place. Fortunately I tested mine and found that the wires in the fixture itself were cooked. Soldered new ones into place before I mounted the light.
Steve E.
1974 Sahara 2002
Morris,
What color is the hotwire you hooked the taillight to?
Thanks in advance!
Edwin
