The weekend's work
jp02ti
Started removing pieces in preparation for the big swap. progress so far:
carbs and intakes off, throttle cable set aside
starter motor off
battery and battery tray out
fuel pump off
Alternator off
rad out and coolant drained
header unbolted
Removed from donor "extra motor" from a '67 2000C Automatic
-distributor housing with the small oil pressure sender unit (stamped '66)
-upper timing chain cover with the threads still present on the hole from the rocker cover bolt. this will go to the machine shop with the head to be matched.
