LUBRICANTS : according to BMW , and for you M1 owners
c.d.iesel
here's your Monday Morning Usless information
from your Mudflap Wearing insider :
1.0 General Information On Final Drive Oil
Final Drive oil or hypoid gear lubricant must conform
with the following requirements because of the high
loads which occur on the profiles of the hypoid gear teeth:
— Load carrying capacity.
— Sufficient protection against seizure.
— Good wear protection.
— Optimal friction and temperature behavior.
— Seal compatibility.
— Aging resistance.
These and other properties are already contained
in brand-name hypoid gear lubricants because of
the high content of EP additives (EP = extreme pressure).
Oil Additives
The factory has not approved oil additives for hypoid
gear lubricants. All final drives are designed in such a
manner that they do not require any type of oil additives.
Any type of additives is fundamentally rejected by
the factory. BMW NA cannot accept any liability for
follow-up damage resulting from the use of additives.
2.0 Approved Final Drive Oils For Front And Rear
Axle Final Drives With And Without Limited Slip Or
Viscous Coupling
Mineral based final drive oils are no longer recommended
due to the release of synthetic final drive oils for all vehicles
with or without limited slip differentials.
Limited Slip Differentials
With the introduction of the Z3 roadster a new synthetic
final drive oil for all vehicles with a multi-plate limited-slip
differential has been released. The new BMW final drive
oil SAF-XJ will replace the old final drive oil SAF-XLS.
The SAF-XLS final drive oil is not to be used in the final drive of the Z3 roadster.
Use only the SAF-XJ in the final drive of the Z3 roadster.
Note: If a non-limited slip differential
oil is used in a limited slip differential a whining or chattering sound
can be heard on very tight turns and will eventually result in
a failure of the differential.
Description Quantity Part Number
BMW Synthetic Final Drive Oil 55 liter drum 83 22 1 470 080
(with multi-plate Limited Slip Differential) (SAF-XJ)
E71 X6 xDrive35i and X6 xDrive50i:
Rear Differential with Superposing Gear Units (QMVH)
The rear differential assembly consists of three separate
filler plugs, one in the center for the angle drive with
differential gear and one additional filler plug on each
of the left and right superposing gear units.
Angle drive with differential gear (center filler plug):
PN 83 22 9 407 768 (SAF-XO)
Superposing gear units (two outer filler plugs):
(SAF-CARBON) This fluid is not available at this time
For more information regarding filler plug locations
and operation please refer to the TIS Website
– Technical Training –
ST710 E71 Complete Vehicle Workbook – E71
Chassis Dynamics Workbook.
Motorsport Vehicles:All E46 M3, E60 M5, E63/E64 M6, E85 M roadster, E86 M coupe and E90/E91 and E92 M3 require SAF-XJ Fluid.
Non Limited Slip Differentials
BMW Synthetic Final Drive Oil 55 liter drum 83 22 9 407 768
(without multi-plate limited slip differential, (SAF-XO)
or with viscous differential lock (325iX/iXA)
Note: See S.I. Bulletin B 33 01 92 for additional final drive oil info.
3.0 Final Drive Oil For BMW M1 Motorsport Coupe
The final drive of a BMW M1 is integrated into the manual
transmission and the oil supply is accomplished with a
mutual oil filling.
Use reputable brand SAE 80 manual transmission oil conforming with specifications MIL-L-2105 A or API-GL 4. (just like our 02 's ! )
4.0 Oil Change Intervals
Maintenance requirements per the vehicle’s Service
Booklet or the respective Service Maintenance Checklist.
Replacement final drives: same as for new vehicles.
Page 3 of 4
All models as of 9/97 production are factory-filled with
synthetic rear axle oil having a long-life service rating.
No oil changes are required for the life of the vehicle.
5.0 Cars Without Service Indicator (Including BMW M1)
First oil change at 600 miles
Further oil changes at 18,000 miles
Special rule for BMW 530i, 528i (E 12):
1st oil change at 600 miles after final drive replacement
2nd oil change at 4,500 miles after final drive replacement
Further oil changes at 9,000 miles intervals, beginning at 9,000 miles.
6.0 Cars With Service Indicator
Refer to Service Maintenance checklist for respective model year.
Break-In Procedures
Drive the car with changing engine speeds and road speeds
during the first 1,200 miles/2,000 km, but never faster than
2/3rds of maximum speed in a selected gear. Avoid using
full throttle and kick-down positions of the accelerator pedal
during this period.
BMW M3/M5/M6 Up to 1,200 miles max. engine speed 5500 RPM
Generally avoid full-throttle position of the accelerator.
These break-in procedures are, of course, also applicable
to replacement final drives.
7.0 Output Shafts
The joints of output shafts have permanent grease lubrication
and require no servicing.
The amount of joint grease required after repairing is supplied
in the “dust cover repair kit”.
8.0 Wheel Bearings
Ball Bearings E24 (Since 5/82), E28, E30, E31, E32 And All Following
Bearing unit is lubricated for its service life, cannot be disassembled
and does not require subsequent lubrication.
Grooved Ball Bearings E12, E21, E23, E24 Before 5/82 ( attention 02 owners !)Grease type:
Retinax A (former BMW Part No. 81 22 9 407 710)
CRC Part No. SL 3131
9.0 Differential Housing Final Drive Covers And Housing
On 735i/iL, 750iL, M6 and M5 (E28) models, the attaching
bolts are to be installed with Hylogrip/Loctite 270 (green)
thread sealant (former BMW Part No. 81 22 9 400 086).
Würth Part No. 8932700
Loctite Part No. 21438
See S.I. Bulletins B 33 01 89 (1869) and B 33 01 88 (1621).
dat is all - Be Happy .
'64 R27 250cc #383851 18,000m
