New Noise from my 2002
I've had my 1976 02 for about 3 weeks. By this time I'm pretty used to the way the engine sounds. Its been running great, great shifting, great power etc. 2 days ago I heard a short "grinding" sound when I started her up in the morning. To me is sounds like this.....imagine 2 metal plates spinning side by side and everyone in a while they get too close and touch for a couple of seconds and then a few seconds no noise and then the touching / grinding noise again. (I'm in now way a person that knows things about cars). I don't hear the sound once I get the car moving but I think that the regular engine sound may just be blocking the new sound.
Today I had to drive it about 20 miles each way to another town. When I got where I was going I stopped the car with the engine still running, put the car in neutral, and walked around the car to see if I could locate the noise. I'm pretty sure its from the engine and I think I heard it louder when I put my ear down low to the ground on the passenger side. I'm certainly not sure that I know where the sound comes from. I'm hoping that its just a loose exhaust pipe banging around.
Otherwise the car is performing great.
Any thoughts before I try and take her into the shop next week?
Thanks,
Morris
loose heat sheild
bad piliot bearing
bad clutch throw-out bearing
broken exhaust baffle
collapsed motor mounts allowing
something to contact something that it shouldn't
keep us posted
Get Down And Get Under the thing
'64 R27 250cc #383851 18,000m
loose heat shield
Are you really suggesting the poster travel all the way to Australia? Quantas has good fares now but why not use a lift? lol
M.
Yea,
I took my 2002 with the new noise by my mechanic after work today. He put it up on the lift right away and said that it was just a loose part of the exhaust pipe. He said its really easy to fix. So to my relief, no engine trouble.
He did notice that my car is hard to re-start if you just turned it off moments earlier. So, he wants to look at that when I bring the car back later this week. I'm glad my starting trouble was not just due to my bad starting style.
Morris
