Weber 32/36 DGV jet & tube options
thomasfrei
I have recently had a 1972 2002 restored, and am at the point where i'm trying to fine tune the engine. I have not disassembled the carburetor that I'm presently using-- I will will certainly do that at some point to see what I already have. Right now I would simply like to have some suggestions from someone who has a fair amount of carburetor experience as to where they might start with the various components:
main jets
main air correction jets
emulsion tubes (does anyone actually experiment with these?)
idle jets
I have a spare, old 32/36 which I can rebuild and just swap off the factory new one that is on the car now. A little more information:
Engine is recently rebuilt to 9.5 compression. 284 Schrick cam. Intake valves opened up to 46mm. Head not really ported, but gasket matched. All suggestions welcome! Thanks.
If you have a DGV carb, then I would start out with this
Primary Idle 60
Secondary Idle 50
Primary Main 140
Secondary Main 140
Primary Air 170
Secondary Air 160
The emulsion tubes in yours, i think are F6 and F50. You can play around to see if changing them around makes a difference.
Overseas Auto
Vancouver BC
1-800-665-5031
always on MSN z5551212@hotmail.com
www.overseas-auto.com
www.weberjets.com
www.piaalights.com
www.thejimhilton.com
I stumbled across this jetting in an eighties roundel, and it is great. No flat spots, comes off idle strong, and keeps pulling. Might be a little rich, but thats better than lean to me!
Primary Secondary
Main Jet 150 165
Air Jet 165 170
Emulsion Tube F8 F8
I'm running 50 idles.
This working out also depends on engine condition HTH
Larry
Further questions on the 32/36. Weber literature makes a pretty big deal about progression holes being covered by the edge of the throttle plate. On both my units (the new one & the old one) the progression holes are not all in the same plane, and for the most part sit obviously ABOVE the closed throttle. Has anyone else observed this? Also, when is the throttle plate ever completely closed? That would be equivalent to having the throttle adjusting screw backed all the way out-- my car won't run like that. Should it? Finally, why is there an idle jet on the secondary unit-- doesn't the secondary come into play only when you pretty much floor the accelerator-- far from an idling situation. Thanks.
Float Level 40mm
PRIMARY
idle 60
main 140
air correction 145
SECONDARY
idle 55
main 170
air correction 175
works very nice.
AND seal off the over-enrichment passage with a
tiny dab of metal epoxy on the secondary side.
and none of the above is wurth a damm if you
don't use a timing light, adjust the valves, have good
compression, and your throttle linkage doesn't give
you FULL OPENING at the carb stop with the pedal to the floor.
'64 R27 250cc #383851 18,000m
Float Level 40mm
PRIMARY
idle 60
main 140
air correction 145
SECONDARY
idle 55
main 170
air correction 175
works very nice.
Hey CD,
I'm going with your prescription, and you forgot to mention to block off the calibrated orifice on top of the secondary barrel. By the way, what do you use to plug it?
Thanks,
Jan1968
73 inka
