2002 carbs
sim02
Hi, im in the process of getting some carbs for my 2002, i've had a look on ebay and there are a few im terested in, would the carbs in my link work good witht he motor? whats the best carbs to go with?? 40, 42, 45mm??
http://cgi.ebay.com.au/Dellorto-DHLA-40-carbs_W0QQitemZ320290234641QQihZ011QQcategoryZ33549QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Thanks
Cheers
Sim
If your set on having dual Webber's,(or Dellorto's like in the add, check for parts availability where you live) you can have ether 40's or 45's. 40's will be the best if you have a stock to mild motor. I had them on my last motor that was around 140 to 150hp. And IMHO, 45's should be only on motors with lots of mods, like 304 or higher cam with 10:1 or higher comp ratio. Some people have got 45's to work on stock motors but there is a lot of tuning and carb parts replacement going on.
John
1665778
Dont bother with the Delorto. there are no jets availalble. The 42 DCOE, there is no venturies available. Your carb to buy is 38 DGAS or twin 45 DCOE. I am the guru
Overseas Auto
Vancouver BC
1-800-665-5031
always on MSN z5551212@hotmail.com
www.overseas-auto.com
www.weberjets.com
www.piaalights.com
www.thejimhilton.com
