121 Head on a 1974 2002 - Gasket?
Andres
Our little yellow 1974 2002 had a bit of a dummy spit and decided it would like to mix it's coolant and oil together. I've pulled the head off, and had it welded and machined so it's ready to go back together (hopefully) but I've discovered in my readings that the 1974 model shouldn't have the 121 head that I've found fitted to our car!
Which leads me to the question, are all the headgaskets the same for the different heads? And also, if there a preferred brand / material / retailer?
Any information would be greatly appreciated!
Thanks,
Andres
1974 BMW 2002 - Golf Yellow
Thanks,
Andres
Andres, the shop that checked the head on my tii mainly builds race engines. The owner told me he only uses Fel-Pro which is what I bought after getting Skips nod of approval as well. So far, so good.
Hope that helps.
Doug
'73 tii Atlantik
Reinz are good too, oem iirc.
I have a reinz now on my turboed engine and it hold 18psi since 2002(year) and has overcome a lot of detonation (while i was tuning the sds).
1985 XR4TI, 22psi ±300hp
