Mechanical/Vacuum Distributor, pertronix...
WBeaumont
Photobucket
Photobucket
Right, at the moment my car is close to being back on the road but i have timing issues. At the moment i have twin carbs on a BMW ti inlet manifold and a vacuum advance distributor (which could be crap and need overhauling, when it was on my 1602 a lot of the problems we put down to timing and it is from a '75 which from what i have picked up is not a good thing for a distributor) which the vacuum bit isn't connected to anything.
I do have another vacuum advance distributor from a '73 2002 touring.
What do i do:
-buy a tii mechanical advance distributor at quite a high cost, probably too much?
-spend some time plumbing in one of my vacuum advance distributors?
-if so which one?
-or do i convert to pertronixs electrical ignition*?
Will
*small question about pertronix on a vacuum advance distributor; do you need to have the diaphragm connected up if you have removed the points and replaced it with a petronix kit? does it still use the vacuum advance? if so how?
That wasn't a small question i know i am sorry, it wasn't even a series of small questions saying it just softened the blow.
For sidedrafts you need a mechanical advance dizzy. Otherwise if you plumb a vac line to one of the cylinders it gets full vacuum and advances too quick - crap running.
Also a Pertronix only replaces the points, it does not change the advancing mechanism, regardless of whether it’s a mechanical or vacuum dizzy.
A board member may be able to help out with a mech dizzy.
Good luck, Beaner7102
