Pagng C.D
C.D,
I know i have seen you discuss your Turbo Diesel on a few occasions, and I have the same car. I have been experiencing weird things with the turn signals. For a few days the turn signals would not "tick". The arrow on on the cluster would illuminate, but not click on and off. Now, it simply doesnt light up or do anything. Relay issue? And if so, where is the relay? Thanks for your help.
Cheers,
Chris
it's the hazard flasher - relay built into it - try another 4-way flasher
switch - try pushing the flasher button several times to 'wake it up'
'64 R27 250cc #383851 18,000m
actually - the 4-way flasher switch and the flasher relay are seperate -
the switch is just a switch -
and the relay that does the ticking and flashing is under the center consol - just in front of the gear shift - lift out the ashtray and
center wood trim/plastic trim to access the relay
