Those with a Sports Steering wheel, I need some measurements
felix_666
I feel like a bit of an idiot, but yes maybe a picture would help.
Isn't the circular plate simply flat with a ID and OD??
Maybe because i don't have this part that it seems confusing.
I really appreciate your efforts Bill.
EDIT: Whoa, that was fast.
While your there could you please grab the shroud diameters.
The pics make plenty of sense - crystal clear.
Also what size is your wheel out of curiosity??
Thanks
EDIT EDIT:
My mistake, i looked over the pics and it makes sense.
I didn't realise the ring/plate had a lower section.
__________________
1972 RHD Auto - Sold
1973 RHD Verona - Project
1974 RHD chamonix - Towed
My shroud is cracked, I have it covered with electrical tape.
I was afraid of trying to fix it as the screws are really tight and I understand NLA.
If you find a source for the screws and if the fabrication of a second shroud is not too expensive, I would consider buying one from you.
Always glad to help.
1972 2000tii Touring #3422489
FAQ member #5
No worries.
I'll let you know how my shroud goes.
I would of thought those screws would be be pretty common. If you give me the specs i reckon i should be able to find them.
My friends works for a Nut and Bolt wholesaler and has found every item i have needed so far, including some pretty fruity bolts.
I'd be happy to try and return the favour.
__________________
