Trunk Water Leak ?
wickstad
Water drips into my trunk from both of those soft plastic vents. Or so it seems. Has anyone diagnosed this before and found a remedy?
one of the vents on my car was dry-rotted around the lip that seats into the hole in the body. this resulted in a leak into the trunk as you describe. i used some silicone to make a temporary repair until i can replace with new.
'71 2002
Check the nuts on the trunk hinge mounted to the uni-body. They usually have dum-dum oozing out. If someone loosened the nuts, you'll need to re-seal them.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
