grounding points in trunk
BLUNT
I grounded mine to my TEP rear battery bar. I also installed a battery cut-off switch (see link) on the neg cable so I can interrupt the ground easy when doing electrical work. It's easier than pulling the cable. I also use it as a anti theft device. I just turn the key to interrupt the ground and take the key with me.
Link:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92688
Phil/Bomb Guy in Colorado
2002 E46M3
2002 E46 325 xi
1991 E30 325ix
1970 2002 M2
1966 Mustang
Link:
I'm oing to add one of those in as well as a big fuse just in case the + line gets grounded accidentally (sat at the point it passes thru the firewall. If it did happen I imagine it would cause a fire or at least fry some other electronics.
Blunt did you run your + line yet? If not I was able to run mine thru the fire wall into the cavity that houses the fuses- kinda kept things neat. NOt a great shot but ou can just see them on the left side.
Your installer buddy must be thinking of bady/frame cars. Use your multimeter and check the resistance from the sheetmetal to different parts of the body. You'll see it is pretty low.
The only way there would be added resistance if if there were really crappy welds and no other path for the current.
Steve J
& too many bikes
