Drip rail moulding (rain gutter) install made easy.
DukeRimmer
All you need is a common welders clamp, a towel, and a little caution. No hammer, no mental strain, no hand strain. Adjust the clamp so that it's 1.5 times the width of the moulding. Start at the center of the curve and work outward in both directions. It will twist into position with the greatest of ease if the starting point is centered in the curve.
Be sure the hood is adjusted so the gap matches the trunk gap. If it's pushed back to match the fender to door gap, the new moulding will suffer, as will the hood paint.
The clamp in the pic is adjusted much too tight.
