solex single barrel carb
Price: $95
Description:
1 barrel solex  carb original BMW factory part tag still attached. A little dusty but looks to be in excellent condition it came with my 73' along with other parts. Asking $95 + shipping
Edited by Rob Jay
lowered asking $
That appears to be the 40mm version for the 2002. There is also the 38mm version for the 1600-2.  I was able to identify it by the larger 30mm Venturi and size 100 pump jet at the bottom of the carb. The pump jet appears to have been removed and disassembled in the past. You can tell by the wear caused by a screw driver. Many of these carbs still have the metal factory tag still attached. Judging by its appearance, your carb may have been lightly used and cleaned at some point . The lid is very much still intact where the vacuum plunger has not worn a hole through it. I would guess it's still a good carb.
Edited by Zak
  • roundtail changed the title to solex single barrel carb
This topic is now closed to further replies.
