WTB: flat top pistons
cmiceli
Dont buy used, too much of a crap shoot unless you can inspect/measure.
If I was needing a set of flat tops I would pounce on these.
NOS Mahle flat tops in 1st oversize with rings, no pins or clips but thats ok, they are pretty hard, your old ones should work.
I know it says 520i but it it fits your 2L M10 block, cause they be the same engine in both cars. I've made a couple of buys from the seller with satisfactory results.
WWW.EBAY.COM
BMW E12 520. Mahle Engine Piston Set w. rings (No Pins). 89.22 mm 1st Oversize. NOS in original box.
Edited by tech71
76 2002 Survivor
71 2002 Franzi
85 318i  Doris
19 minutes ago, cmiceli said:
How much you asking ?
$100+ shipping.
I also have a set of std bathtubs, not high compression that were used about 500 miles.  Needs a 121 head to use.  I pulled the flat tops to try these, then I got crazy and built up a second engine and neither set were needed.
Flat tops are Mahle, bath tubs are Klobenschmidt.
