FS: 72 2002 (Lexington, Ky)
Price: $8800
Description:
This 2002 is something I put together a year ago. Now offered for sale again in the same condition by its new owner who purchase Greg Bare's M20 swapped car and no longer needs the project. Price is 8800 OBO!
Parts list (New as of Winter 2019)
Ireland Engineering Stage II springs
Bilstein struts/shocks
Rear poly shock mounts
Suspension Technique front sway bar
Ireland Engineering poly sway bar bushings front and back
Ireland Engineering poly front bushings (comprehensive)
Ireland Engineering idler arm bushing
Ireland Engineering poly engine mounts
Condor Speed Shop transmission mount
New Moog ball joints
New tie rods
New steering arm
New top mounts
New front calipers
New front rotors
New front pads
Condor Speed shop stainless brake lines
All new solid brake lines
Condor speed shop stainless clutch line
New rear wheel cylinders
Freshly rebuilt pedal box
Ireland Engineering poly steering coupler
Ireland Engineering poly alternator bushings
New clutch slave cylinder
New master cylinder
New master cylinder hoses
Ireland Engineering silicone coolant hoses
New water pump
New thermostat
New coolant temp switch
New spark plugs
New spark plug wires
New gas lines
Refurbished gas tank
Refreshed gas level sending unit
New drive belt
Oil pan gasket
Valve cover gasket
Oil filter housing gasket
Oil change
Oil filter
Transmission fluid
Diff fluid
Steering box fluid
New tires
Newer battery
New battery leads
Additional info:
Numbers matching motor and transmission
Weber 32/36 electric choke
New air cleaner
Fresh coolant flush
Fresh brake bleed
Fresh clutch bleed
e30 sport seat
Ireland Engineering front tow hook
e21 sport wheel
All belt line trim included
Rocker trim included
Yes, I have the rear quarter glass
New subframe hardware
All gauges work as they should
All lights work as they should
All emissions system and wiring removed
Wipers wipe
All 4 hubcaps included
Driver’s flag style mirror included
Original steering wheel included
Spare wheel
New starter included
Can provide cold start videos, running/driving, and walk arounds of requested items or areas of concern.
PRICE IS OBO!!!
Edited by 72tiiWishfulThinking
  • 1 month later...
