Emergency flasher and turn signal relay wiring
Lars Armyr
E10 - 2002 1974 modell.
Need help with some wiring for the turn light- / emergency light relay.
Two wires (one red/white and one brown/blue) was disconnected during disassembly. Everything was working before this happened.
Any one that knows were they should go ?
The Red/White wire comes from fuse #2 (always hot w/ 12V) and goes to the Hazard Light button on the center console.
It also goes to connection #2 on the instrument panel, and to the interior light switch above the driver's door.
Should be 12 volts at all times.
The Brown/Blue wire is for the brake pressure balance switch....If your car has one (my '76 does not).
