Crank No Start Issue
Tknackstedt
Hi Thomas,
        #1, do you have a test light? If not, buy one, you'll need it owning a vintage car.   #2 With the ignition in the on ( run) position, test to see if you have power to the  + side of the coil ,which is where that famous wire is plugged in. #3 If you have power to the + side of the coil,turn the key to off,  disconnect that wire from the + side of the coil and plug it into the - side of the coil and plug the other end into the distributor.  Now if the points didn't get fried from plugging in that wire before and you have fuel, try to start it.   Call me if you'd like.
Dan in Colorado    719 688 1931
