Question for those with the I.E aluminium radiator
Tdh
That's a bit of a vague question " What is the overall thickness "  I can tell you the tank is larger and the core thickness is larger than a stock two core radiator  Will the fan hit it ? That's  not an exact science All cars are a little different. If you have even a 1/4 inch clearance from the front of your fan to the radiator than it would will most likely be OK
Call IE and see what they tell you  Or do a search on Radiators for many opinions and suggestions about radiator options
I just need to know the thickness of the I.E. radiator.  So, if anyone has one, could you please measure it’s thickness?  Im not interested in how close the core is to the fan, but rather the thickness of the top/bottom tanks (presuming they’re the same).
Thanks,
Travis
