1987 BMW 528e LS1+T56 Swapped
ma.jomaa
Price: $18950
Description:
Up for sale is my 1987 e28 with an LS1 swap with working AC and heat. All work was done at JMP AutoWerkz in Reseda.
The list of work done/parts involved is not all inclusive as I will not remember every nut and bolt used to complete the build.
Used Parts:
-LS1 with around 80K miles. Engine was resealed and a new water pump was installed
-Rebuilt T56 Transmission
-LS6 intake manifold
-Resealed 3.73 Small Case LSD
-Euro Bumpers
-Euro Headlights
-Euro Turn Signals
New Parts:
-GTO Oil Pan
-Pro 5.0 Short Shifter
-Aeromotive Adjustable Fuel pressure regulator
-New high pressure fuel pump
-Chromoly pushrods
-CSF Radiator
-16'' Spal fan
-Water Pump
-AC Compressor
-AC Lines, AC Condenser and Drier
-Heater Blower Motor
-Condenser Fan
-Diamond Stage II Clutch
-Spark Plugs and Wires
-Porsche 944 Brake Booster
-e32 brake Master Cylinder
-e34 M5 Brakes all around: New calipers, Rotors and Pads
-Custom one piece driveshaft
-Federal RSRR tires in 235/45/17 (Less than 500 miles on them)
-New euro bumpers rubber trim.
-VDO Oil Pressure gauge
-VDO Temperature gauge
-Innovate Motorsport Wideband AFR gauge
-Custom headers to clear steering box
-Engine and transmission mounts
-Tie Rods
-Upper and lower control arms
-Idler arm
-Steering Center link
-Sway bar links Front and Rear
-Rear Pitman Arms
-MAP Sensor
-IAT Sensor
-AC and Drive Belts
-Expansion Tank
-QTP electric Exhaust Cut out
-Custom 3'' exhaust,with mid section muffler, high flow cat, and rear magnaflow muffler.
-Euro Bumper brackets
Dyno tuned at New Era Performance LLC in Agoura hills, it made 303hp and 330ft/lb TQ at the wheels.
Asking price is $18,950 Please don't waste my time or yours with low ball offers.
This is a for sale post, and not a survey of whether you agree with what I did to the car or not, lets keep negative comments off the post please.
I can be reached at 818-703-2097 Call or text
Below is a link to google album of the car.
https://photos.app.goo.gl/nCsfu04BUlY0nzy33
1979 e21 318 (sold)
1975 Inka (sold)
1983 e21 320i (sold)
1974 Polaris (sold)
1975 M42 Swap (work in progress)
